tubetype | -- 04-28-2013 @ 5:44 PM |
book says use 20/30 weight oil. Can I use modern 5-30 oil?
supereal | -- 04-28-2013 @ 8:52 PM |
That is likely a bit thin. I'd opt for 15-30 or. 15-40. Non-synthetic will leak less, in most cases, as primitive seals tend to seep with full synthetics.
TomO | -- 04-29-2013 @ 8:55 AM |
If it is a flathead Lincoln, use 20W-40. If it is the overhead valve engine, use 10W-30. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=15&Topic=5980 |
