RAK402 | -- 06-22-2016 @ 11:25 AM |
I have been looking at the clips that came with my LeBaron Bonney upholstery kit. There is a bag with a large quantity of clips, which I assume are for the door panels. The original clips (those which remain) on the metal pieces that are fabric covered and go around the windows in the doors appear to be different. Does it make a difference? Are the correct ones reproduced? Am I being too picky? Thank you all in advance.
kubes40 | -- 06-22-2016 @ 12:56 PM |
You will need the correct clips to properly install the side window trim pieces. Lebaron sells them. If you are not certain which ones they are in the catalog, call there and ask Wendie.
RAK402 | -- 06-22-2016 @ 3:06 PM |
Thank you sir! I will call Wendie and get the correct clips!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=9805 |
