donnicoli | -- 03-01-2016 @ 3:38 PM |
on a 1940 sedan delivery is the fuel line connecetion at the tank done with a flare fitting? see photo of tank
ken ct. | -- 03-01-2016 @ 4:13 PM |
No I think that 1/2 x 20 compression fitting and ferrel like on the carb inlet. ken ct OMO
donnicoli | -- 03-01-2016 @ 9:02 PM |
that's what I thought, I used a ferrel and it leaked! The seat in the tank is not tapered to accept the ferrel and it did not compress? the seat is flat not tapered, that's why I thought maybe it needs a flare?
ken ct. | -- 03-01-2016 @ 10:46 PM |
Is it possible someone in the past installed the wrong fitting at the tank. Don't think ive ever seen a flared gas fitting on a ford back then. ??? It would have to be a double flare if so. (diff than a single flare) ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=9448 |
