fortyford | -- 09-07-2015 @ 6:09 AM |
My vent glass is not sealing up against the window.Is there an adjustment to help this? This message was edited by fortyford on 9-7-15 @ 10:20 AM
kubes40 | -- 09-07-2015 @ 6:40 AM |
Please explain exactly where the issue is. Do you mean the vent glass is not sealing against the roll up window track? If that's the case, there is some adjustment that can be made with the forward vertical track as well as the window regulator. Is the vent window tight at both the top and bottom (rivets) pivot points?
fortyford | -- 09-07-2015 @ 10:19 AM |
Kube,It is a good bit off from the roll up glass.Everything is tight and the vent window seal fits good.Here is a photo. http://i982.photobucket.com/albums/ae308/leonharu/GLASS.jpg
kubes40 | -- 09-07-2015 @ 10:36 AM |
From your photo I'd suggest you start with the vertical channel adjustment. How are the "whiskers" and other insulating channels? Are they worn out or proper?
fortyford | -- 09-07-2015 @ 11:59 AM |
The roll up glass channel is worn bad and needs replacing.I do have the anti-rattler kit for both doors.What are the whiskers?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=8953 |
