RAK402 | -- 08-18-2015 @ 10:57 AM |
I am getting ready to install the rubber seals for the wind wings (the old seals were removed a dozen years ago). Are these riveted in? Is glue also used? Thank you all in advance.
kubes40 | -- 08-20-2015 @ 6:36 AM |
No glue is needed nor required. The seals are riveted in two places as I recall. A bit of advice? Install both "open ends" first and insert the rivets near each end. Then work the remainder of the strip in place. A little glass cleaner acts as a lubricant and makes this installation easier to accomplish. Mike "Kube" Kubarth
RAK402 | -- 08-20-2015 @ 8:57 PM |
Thank you, sir!
RAK402 | -- 10-04-2015 @ 2:13 PM |
Mike, Thank you for the advice, sir! It worked great! I have now replaced the rubber seals for the rear windows, the rear wind wings, and the front wind wings. This required plastic tools, lots of soapy water, and a great deal of *@!&*$@*!!!, but it is now done!
kubes40 | -- 10-05-2015 @ 12:27 PM |
Sir? Mike works just fine ![]() Glad you got all of that accomplished. The vent windows seem to be the most "trying" in my opinion.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=8880 |
