40standardcoupe | -- 01-13-2015 @ 3:22 PM |
How do you get the trunk lock cylinder out of the handle? I need to change the trunk lock cylinder. Handle has been removed from car. As always, thanks for your advice.
TomO | -- 01-14-2015 @ 8:31 AM |
Turn the cylinder to the unlocked position and then insert a thin probe in the space at the top of the cylinder to depress the pin that keeps the cylinder in place, then pull the cylinder out with the key. I have tried this procedure and if I had to do it again, I would take the handle to a old locksmith and have him do it. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=8105 |
