40standardcoupe | -- 03-26-2014 @ 9:13 AM |
Does anyone have photos of the correct manifold for an early 1940 ford standard coupe 85 hp? Or a good description including location of vacuum ports, etc.
kubes40 | -- 03-26-2014 @ 5:18 PM |
Here's a photo... Mike Kubarth
40 Coupe | -- 03-27-2014 @ 4:16 AM |
Note in Mikes picture on the 1940 cast iron manifold, on the LH side of the manifold where the bolt holes are for attachment. There is a forward port for the distributor vacuum and near the rear a second port for the wiper vacuum. There is NO port under the carburetor for vacuum.
kubes40 | -- 03-27-2014 @ 6:42 AM |
40coupe, That is correct. The valve chamber covers with that port below the carburetor base are a later design.
carcrazy | -- 03-27-2014 @ 11:12 AM |
How steady of a vacuum reading would be obtained from a gauge attached to either of the two vacuum ports available with this intake manifold?
40 Coupe | -- 03-28-2014 @ 5:13 AM |
Typically the vacuum at the wiper port is steady as a rock for an engine in good condition. If not double check the vacuum gauge on a good engine, before looking for problems.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=7161 |
