bobgrice | -- 02-07-2014 @ 4:25 PM |
Does anyone have a good color match for the kick panel mouldings at the front edge of the doors, under the dash? I understand this brown was a bit darker than the Medium Brown that covers the rear view mirror, sun visor brackets, courtesy lamp bezel and courtesy lamp switch cover.
supereal | -- 02-07-2014 @ 6:40 PM |
I have used a Rustoleum color called "leather" that is a close match. I don't use Rustoleum much, but this one is close. I use "sand" on convertible top exposed linkage. Just be sure the surface is completley free of any other coatings before application.
bobgrice | -- 02-08-2014 @ 5:25 AM |
Thank you, Supereal. I hope others chime in as well - I'll check out the "Leather" color you mentioned.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6997 |
