donnicoli | -- 12-26-2013 @ 5:29 PM |
1940 Horns, How do you get the rubber gromets that go around the horns where they sit in the brackets on?
wmgmitchell | -- 12-26-2013 @ 5:56 PM |
Good question. As far as I know, the only way to get them around the horns is to cut them and glue the ends together afterward. Kube will have the definitive answer. Bill
salina | -- 01-24-2014 @ 11:29 PM |
Grab the pin, very close to the bottom with "Vice Grip" type pliers, making they as tight as possible. Then use a screwdriver as a pry bar, pry the vice grips straight up. The pin is serrated and will not turn but it will come straight out. salina
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6854 |
