Kenneth M. | -- 10-30-2013 @ 2:05 PM |
On my 40 Conv. I think the top control is where the columbia switch should go. No 2 I need the spects to line up the front end. Kenneth M. Stewart
kubes40 | -- 10-30-2013 @ 5:18 PM |
There is no specific place for the Columbia switch as Ford did not authorize the installation of a Columbia in 1940. Thus, the entire unit being incorrect upon the concourse means you can put the switch anywhere you please. Front end: Toe-in is 1/16". Camber is 1/4° minimum, 1° maximum. Variation between wheels should never exceed 1/4°. Castor is 4 1/2° minimum, 9° maximum. No more than 1/2° variation between wheels. Mike Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6671 |
