mike1 | -- 10-19-2013 @ 2:41 PM |
what was material utilized on trunk panel & how was it installed underneath brace panels? it appears to have a matte pattern maybe??
ford38v8 | -- 10-19-2013 @ 3:59 PM |
Mike, The original material was installed before the outer skin, thereby entrapping it between the skin and inner brace. Restorers today must cut the material to fit like a jigsaw puzzle between the braces. I know a correct substitute material is available, someone else can tell you the name of it and where to get it. Alan
kubes40 | -- 10-20-2013 @ 5:24 AM |
Drake sells a pretty good reproduction of this material. He calls it "waffle weave insulation". You can piece it in as mentioned previously or if you are like me and want a beautiful (and authentic) job, remove the inner structure of the lid, install a full piece and reassemble the lid. Mike Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6632 |
