mike1 | -- 10-13-2013 @ 2:22 PM |
I am removing original headliner from my 40 sedan; after removing headliner their appears to be a bonded padding material glued to the roof; what is material and any ideas on any material to remove this tight bonded material?? Any suggestions would be appreciated!
kubes40 | -- 10-13-2013 @ 5:37 PM |
Ford installed a heavy tar paper on the roof for sound deadening purposes. It is quite similar to the material that authentically lined the tool tray. Drake calls it 'waffle weave" I believe. Regardless of what is is properly termed, it is a tar paper. As such, you can scr*pe this with a stiff blade putty knife and most will come off. If you insist on removing all of it, a heat gun makes the process quite easy. It does not require much heat to loosen up the old glue. Mike Kubarth
woodiewagon46 | -- 10-15-2013 @ 3:43 PM |
I would reline my metal roof with a product called Dynamat. It cuts down on the heat transfer and deadens the sound, you won't regret it.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6614 |
