shogun1940 | -- 08-14-2013 @ 7:17 PM |
on a 40 ,how many leafs does it have,how wide, and what lenght when installed and uninstalled
deuce_roadster | -- 08-14-2013 @ 8:23 PM |
You need to supply more specific information. There are probably at least 20 different springs when you consider front and rear and all the different body types and engines.
shogun1940 | -- 08-15-2013 @ 6:51 AM |
its 40 convertable ,, i want to check the width of the spring perches also and it is the front I am concerned with This message was edited by shogun1940 on 8-15-13 @ 6:53 AM
kenburke | -- 08-23-2013 @ 12:51 PM |
The answer on most 40 spring leafs is 10. New thread on rear spring. I am cleaning mine up (don't ask). It appears that there are no rear spring clamps having the protective sheath only visible. Also, on shackle clamps and the stamped "M" per the book. What is really required? Also what color should they be?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6409 |
