easyrider | -- 08-14-2013 @ 5:58 AM |
How was/is the two special top snaps on each trim piece(banna clips if you will) properly/correctly attached? My upholstery guy wants to use pop rivets. If someone could send a close up picture of one that has been done correctly would be very helpful. Thanks Eddie
kubes40 | -- 08-14-2013 @ 9:33 AM |
There were two different designs of snaps in this area used in 1940. By your question, I will assume you have the type that utilize two small flat head (slotted type of course) screws to hold the clip to the body. Mike "Kube" Kubarth
easyrider | -- 08-15-2013 @ 5:06 AM |
Yes sir, I have the ones that Dennis Carpenter sells. Is the front snap a stud type snap? Would the slotted screws be oval head like most of the ones Mr Ford used. Thank you for your input. Eddie
kubes40 | -- 08-15-2013 @ 4:40 PM |
The screws are flat head in this area.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6407 |
