Pete | -- 05-21-2013 @ 9:36 AM |
I am in need of help in re-assembling the air vent open-close assembly. Is there a picture of the unit assembled as well as adjustment procedure? I do not have any manuals that have helped in this arena of problems. Thanks.
kubes40 | -- 05-21-2013 @ 11:34 AM |
Here's one picture I had handy. it should help you. Adjustment is fairly easy. Fit the lid to the opening first. You do this by adjusting the four nut / bolt assemblies that attach the lid to the mechanism. Once the lid fits to the opening properly, you may adjust the how tightly the assembly will close at the "slide".
kubes40 | -- 05-21-2013 @ 11:35 AM |
Sorry... forgot the picture...
Pete | -- 05-21-2013 @ 10:38 PM |
You're right, this will help a lot----thanks!
40 Coupe | -- 05-22-2013 @ 3:03 AM |
This may also help, it's from Bob Drake. This message was edited by 40 Coupe on 5-22-13 @ 3:05 AM
Pete | -- 05-22-2013 @ 5:46 AM |
Thanks again, the forum has been a huge help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=6069 |
