wmgmitchell | -- 10-24-2012 @ 6:33 PM |
I bought a new floormat for my 40 coupe. Can someone please tell me where the two clips go that hold the mat in place? The clips werent used with the old mat. Much obliged! Bill
kubes40 | -- 10-25-2012 @ 6:34 AM |
Hey Bill, There should be two holes in your transmission floor cover that accept the clips. One hole on each side of the "hump". I have attached a photo to give you an idea where to look. As a side note, ALL models of 1940 Fords, both "standard" and deluxe, used Benton Gray mats. The closest reproduction is taupe. Mike "Kube" Kubarth
trjford8 | -- 10-25-2012 @ 8:32 AM |
Just for info the repo tunnel covers do not have the holes for the floor mat in them. If you have a repo cover you will have to drill the holes.
wmgmitchell | -- 10-25-2012 @ 4:10 PM |
Thanks very much, guys this is quite helpful I have an original transmission cover and someone put screws where the clips should go. Bill
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=5339 |
