std1940 | -- 08-15-2012 @ 4:11 PM |
What is the best way to put more tenision on the fastner that holds the lock cover on a 40 coupe trunk handle? Mine is too loose but still attached. Thanks Tom.
kubes40 | -- 08-15-2012 @ 5:36 PM |
I have found the need to repair one of these many years ago. I had a helper push down the spring with a couple of small screw drivers while I built up a little solder on the pin. It actually worked quite well.
TomO | -- 08-16-2012 @ 7:32 AM |
I removed the crimped nut on the shaft and then used a new spring. This works only on the Ford part, the reproductions will not stand the force needed to remove the nut. Tom
std1940 | -- 08-17-2012 @ 5:20 AM |
I have now noticted that the spring is gone. How do you remove that crimped nut and what did you use for a spring? Thanks Tom.
TomO | -- 08-17-2012 @ 2:36 PM |
The nut on mine was a brass nut and I used a pair of pilers to flatten the peened over flare enough so that I was able to pull the nut off. I found a spring that was the same diameter at the hardware store. I just cut it to length. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=5072 |
