DougieGB | -- 02-01-2012 @ 3:21 PM |
I am getting confused! I have read conflicting accounts as to wether my 1940 Ford Coupe should have One (1) or Two (2) Temperature sending units installed on the engine. One article I read says that until 1941 there was only one Temperature Sending Unit installed on the drivers side. Another article I read says there was a Temperature Sending Unit installed on Both sides. What is the correct answer, One Side or Both? Single post or Double post?
deuce_roadster | -- 02-01-2012 @ 9:24 PM |
Only 1 on the drivers side head. Single screw in top. The double post one is actually only a switch and is for later cars. Roy Naceowicz sells the correct brass plug for the passenger side head if you don't have a hot water heater, otherwise the shutoff valve goes in this head.
DougieGB | -- 02-01-2012 @ 10:53 PM |
Thank you for the information.
kubes40 | -- 02-02-2012 @ 8:09 AM |
Dougie, Duece is 100% correct on this. No need to be confused any longer ![]()
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=4292 |
