kenburke | -- 12-29-2011 @ 5:31 PM |
Hi Mike, So what are the correct bolts, nuts and washers for connecting the yoke to the front inner fender panels. My car is black. So what would be the correct color? Thanks, and Happy New Year!
kubes40 | -- 12-30-2011 @ 12:50 PM |
Hi Ken, I can't put my fingers on the part numbers at this moment but can describe the necessary fasteners (hopefully) adequately for you. The fasteners that hold the brace to each inner fender panel are all S2, raven black. The bolts are hex head, 3/8 - fine thread. The bolt is inserted from the engine compartment, The lock washer and nut were on the outer side of the fender panel. A small anti-squeak pad was placed between the pan and the support. If you need more specifics such as length, part numbers, please let me know. Kind regards and happy new year to you! Mike
kenburke | -- 01-03-2012 @ 2:23 PM |
Mike, That covers it, and I found that Roy N. has a kit #R-92-16 that has the S-2 bolts and nuts, etc. Thanks Again
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=4167 |
