DHunt | -- 08-15-2011 @ 10:52 AM |
My headlamps are pointed too high and I'm not clear how to re-direct them. The only hardware is the large nut under the fender where the wires pass through which secures the lamp to the fender. I would appreciate any advice on how to adjust the lamps. Thanks
40 Coupe | -- 08-15-2011 @ 1:36 PM |
loosen the nut under the fender and move the headlight so it points further down. Then tighten the nut.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=3591 |
