fatfender | -- 03-07-2011 @ 9:44 AM |
My '40 convertible has 411 gears in the back. Were these stock? Did 40's also come with other ratios? What ratios were considered stock for passenger cars? Thanks
supereal | -- 03-07-2011 @ 10:35 AM |
The more common rear end gears were 3:78. Unless your car was sold in mountainous country, it is likely the axle was swapped out sometime. Some prefer 3:54 gears, but the open car is somewhat heavier than the closed models. The 4:11 restrains the top speed, of course. Another "fix" is to consider the installation of an overdrive unit. I'd opt for a 25% OD. That would give you the equivalent of about3:09 for hiway driving, and get you above 60 mph, yet allow good power in city driving. I have an OD in my '47 convertible, and it really helps for hiway travel.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=2717 |
