NOS40kid | -- 02-25-2011 @ 3:52 PM |
looking for any info on the original 40 dash color in urethane, single stage. Have found several colors that seem correct but would like to get it spot on. any help would be much appreciated
TomO | -- 03-01-2011 @ 9:44 AM |
If you have original samples, like the glove box door, you can have it color matched at your local paint distributer. If you don't have the original sample, go to http://www.tcpglobal.com/autocolorlibrary/ and have them mix it for you Tom
beau | -- 03-15-2011 @ 10:49 AM |
Hey Nos I just went through this last fall on a Deluxe, if You can't find what You want at TCP Global contact Roy Nacewicz at WWW.fordbolts.com and tell him what your looking for ,, he should give you a set of LAQ numbers take this to your PPG dealer and have him mix acouple oz. each . ( I have the numbers 4 the Brown that you will need) then spray these on a prepared metal sample, take these back to your dealer and have him use his Color match camera, he can then match it in modern paint This message was edited by beau on 3-15-11 @ 11:09 AM
beau | -- 03-15-2011 @ 11:57 AM |
Here are the numbers for the Brown ,, your paint supplier will know what they mean SKU,,,,Disc,,,,,,,,,,INC.,,,,Cum(part) J53-trans red oxide--207.8,,,207.8 j86-jet black--------15.9 ,,,223.7 j56-perylene maroon--3.6 ,,,,227.3 jx995-accelerator----7.3 ,,,,234.6 j70-med.alum---------7.4 ,,,,242.0 j58-Quindo violet----97.8 ,,,339.8 j94-clear------------171.7 ,,511.5 The guys on this forum can tell you what it goes on for the standard car , on Deluxe it goes on Rear view mirror, kick panel trim, sun visor mount ,,,, This message was edited by beau on 3-15-11 @ 11:58 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=2656 |
