MikeJ | -- 11-13-2010 @ 6:55 AM |
Hi Mike, I plan to install a new fuel line from the tank up to the firewall / flex line. Can you provide photos that show the correct routing and clip locations on the inside of the LH frame? I especially need direction on how the line is supposed to pass through the frame under the clutch & brake pedal area and then up to the bracket on the firewall. From the pedal area forward and up this seems to be a very "busy" area with the fuel line, brake line and wiring all passing through and sharing the same area. Thanks for your usual outstanding guidance!
kubes40 | -- 11-13-2010 @ 1:39 PM |
Hi Mike, Thanks for the kind words. I certainly don't feel as if I deserve them but thanks nonetheless! Can you email me direct at kubes40@att.net? I will send the photos directly to you. I have no clue how to insert photos on this site. ![]() My regards, Mike
TomO | -- 11-15-2010 @ 8:20 AM |
Mike, inserting photos on this site is very easy. Just under the box where you type in your reply is a box that says 'Image Attachment'. Click on the 'Choose File' box and a pop up of your Pictures folder should appear. Select the photo that you want and click on 'Open'. It will then upload the photo to this site. Try it with your photo of fuel line routing. Tom This message was edited by TomO on 11-15-10 @ 8:22 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=2168 |
