MikeJ | -- 10-25-2010 @ 9:36 AM |
What is the proper routing of the tail lamp wire (harness) P/N 14424? Is it attached cross-car on the rear spring crossmember flange or on the rear-most crossmember? And, how are the tail lamp conduit / wires routed to connect to the lamp harness? Do they pass through the gap between the body and the frame? Thanks!
kubes40 | -- 10-25-2010 @ 10:44 AM |
The main harness runs along the left frame rail to the very rear cross member. There it is connected to the crossover harness. The crossover harness runs along the very rear cross member being held in place with normally two clips. You are correct in thinking the lamp wires were routed through the small space between the body and frame. If you would like detailed photos, I'll need your email address. Regards, Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=2067 |
