bp1940 | -- 03-16-2025 @ 4:58 AM |
I removed the handles and door trim panel on my 40 Tudor yesterday. The door check retainer was broken. I repaired that. The window regulator needs adjustment also. I noticed that the inside door handle was loose.. When I removed the door panel, only one of the three screws were present on the handle pivot. The other two were in the bottom of the door. I think the last person didn’t have the correct size screws/bolts and the holes might be stripped. They just spin when i tried to put them in. I have a good selection at home and nothing works. Does anyone know the correct thread pitch? I work at dealership and I have a large selection. I might just use self tapping if I have no other choice.
kubes40 | -- 03-16-2025 @ 6:11 AM |
Those were #12 screws. You may have to drill and tap to 1/4" if the last guy ruined the threads. Mike "Kube" Kubarth
bp1940 | -- 03-16-2025 @ 4:22 PM |
Thank you again. The next issue will be the window regulator adjustment.
40 Coupe | -- 03-18-2025 @ 4:26 AM |
There are special star lock washers for the screws
TomO | -- 03-18-2025 @ 6:17 PM |
Third Generation Parts has the correct screws and star washers. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=17494 |
