bp1940 | -- 03-08-2025 @ 6:53 AM |
I purchased an NOS headlamp switch for my 40 Tudor on eBay. In the photos the spades/pins didn’t look bent. Are they supposed to look like this? If not I think I better bench test it, it looks like a tight squeeze because of the radio speaker. Thank you, Brian This message was edited by bp1940 on 3-8-25 @ 6:54 AM
kubes40 | -- 03-08-2025 @ 7:15 AM |
The spades were straight / perpendicular to the body. Yes, with a radio, it's a tight fit. I assume you know the radio must be removed to replace this switch. There should be a piece of rubber glued to the edge of the radio body that will press against the lip of the instrument panel once installed. This rubber strip was advised in a service letter sent to dealers back in 1940. Mike "Kube" Kubarth
bp1940 | -- 03-08-2025 @ 7:28 AM |
Thank you for the reply. We are greatly blessed to have you on here. I was going to do all of the work on this myself. I crawled under the dash and said nope!! I been a parts guy for 40 years. This job looks like one for my younger technician buddies.
kubes40 | -- 03-08-2025 @ 11:20 AM |
BP, where are you in Wisconsin? Mike "Kube" Kubarth
bp1940 | -- 03-08-2025 @ 12:52 PM |
I work at a dealership in Green Bay, I live between Black Creek and Bonduel. About 20 miles north of Appleton.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=17480 |
