Topic: wiper hose
tweetsmith01    -- 11-20-2024 @ 8:04 AM
  wonder what size the wiper hose is for a 40 coupe the book says 1/4in what is od so it fit the grommet
40 Coupe    -- 11-20-2024 @ 2:24 PM
  The vacuum hose is sized by the I.D. both the manifold side and the motor size are the same, measure the connection at the motor. or take the motor to the supply store.
tweetsmith01    -- 11-20-2024 @ 4:40 PM
  my son took the wiper motor to napa they gave him 3/16 windowwasher hose
kubes40    -- 11-21-2024 @ 7:22 AM
  It is 1/4" I.D. The outer diameter of modern hose is smaller than the authentic stuff. It should be tight going through the grommet. Spray the hose with glass cleaner to make it go through easier.
tweetsmith01    -- 11-21-2024 @ 12:41 PM
  will do thank you
kubes40    -- 11-21-2024 @ 7:24 PM
  I should have mentioned, I use fuel line hose. It has a larger outside diameter than vacuum hose. Remember 1/4" inside diameter...
This message was edited by kubes40 on 11-21-24 @ 7:24 PM
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=17318
