Topic: vacumn wipers
tweetsmith01    -- 11-07-2024 @ 5:14 AM
  what is the easiet way to remove a vacumn wiper motor from a 40 coupe it has a radio and a heater i am 81 can crawl under the dash anymore looking for suggestions i would also like to pass info along to anyone in need that charlie schwendler is back doing what he does best he just rebuilt a 40 fuel pump for me last week i read a post on ford barn that he closed but it was only a short time
thanks
kubes40    -- 11-07-2024 @ 6:14 AM
  At our age, there is no "simple" method to remove the wiper motor.
One must crawl beneath the instrument panel and remove the spring load clip that keeps both arms in place. Also, at that time, the vacuum hose should be removed from the wiper motor.
The radio and the heater are not in the way to do this.
Then, working from below the hood, remove the two 5/16" bolts that fasten the wiper motor bracket to the dash panel.
You could I suppose simply allow that assembly to fall to the floor of the car.
Installing this assembly will require a person on both sides of the dash panel. One to hold the bracket / motor in place while the other installs the bolts through the dash panel.
carcrazy    -- 11-07-2024 @ 9:31 AM
  When working under the dash board on these early Fords, I have found it useful to first remove the front seat so you can lie on your back and look up to better see and access the work to be done.
tweetsmith01    -- 11-07-2024 @ 9:42 AM
  thanks kube
tweetsmith01    -- 11-07-2024 @ 9:44 AM
  yes before i got to be a old man i put a bed pillow on the floor and lay upside down on the seat so i know what you mean thank you have a good one
fortyford    -- 11-09-2024 @ 5:23 AM
  If your wiper motor is in need of repair while you have it out you can send to Ficken Wiper Service.
https://rebuildingtricowipers.com/
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=17298
