Topic: oil pan gaskets
pauloma    -- 03-18-2024 @ 11:36 AM
  I am getting ready to put new oil pan gaskets and seals on a 100 hp ford flathead, any suggestions
sarahcecelia    -- 06-01-2024 @ 1:53 PM
  Yeah!
If you also replace the front and rear crankshaft seals;(which should be done with the pan gasket replacement) be sure you install them at an angle to the oil pan flange.
If you put them parallel with the oil pan flange; (Where the PAN GASKET is installed)-They WILL LEAK!!That's a cetainty!!!
Regards, Steve Lee
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=16957
