682bear | -- 10-31-2023 @ 9:28 PM |
The car is a 1940 Deluxe Fordor with a 59A engine... I'm wanting to temporarily install a couple of temperature guages... one for each side of the engine... just to keep an eye on the operating temperatures. I am planning on this being a temporary installation. I've bought two mechanical guages... but I haven't found a way to run the tubes from the guages to the heads without boring holes through the firewall... I'm not interested in doing that. I've been looking for a source for 6v electric guages... wires can be run through existing holes in the firewall easily. So far, I've found two sources for 6v guages. Westach sells them, but has a 4 to 6 week lead time... and the early Jeep suppliers also sell 6v guages, but only in 4 or 5 guage kits... which I don't need. I'm looking for a solution to this issue... any ideas or advice would be appreciated. -Bear
alanwoodieman | -- 11-01-2023 @ 5:23 AM |
run the gauge tubes down thru the hole created for the steering column--remove the plates surrounding the cut out
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=16743 |
