plymboy | -- 06-10-2023 @ 1:52 PM |
Who or where have you guys been sourcing the reproduction batteries from....also is there a faux case that is Ford script and you put a 6 volt Optima inside???
RAK402 | -- 06-11-2023 @ 11:17 AM |
I got mine from here: https://batterycentralmall.com/product/ford-antique-auto-battery-1940-1951-2hf-rr/ Not cheap, and it took a while to get it, but well worth it. As I recall, it has an AGM battery inside. It is sealed, but if you open the three vent covers, you can see a separate/sealed battery inside with cables running to the external posts. When the battery inside dies eventually, I plan to remove the bottom of the case and swap it out. They make these in six or twelve volts (or at least did when I purchased mine about a year and a half ago), so make sure you order the correct one. This message was edited by RAK402 on 6-11-23 @ 11:20 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=16465 |
