kenburke | -- 04-06-2022 @ 3:55 PM |
I keep forgetting. On the two small back windows, are the locations at the outer or inner corners?
ford38v8 | -- 04-06-2022 @ 11:29 PM |
As I recall, one of each, passenger side readable from the exterior, driver side readable from the interior. Wait… I thought you were asking about the rear quarter windows, readable from which position. I believe the same would apply to the rear windows, but position on those windows, I’m not certain, but would think would be to the left and the rught rather than together in the middle. Alan This message was edited by ford38v8 on 4-6-22 @ 11:36 PM
kubes40 | -- 04-07-2022 @ 5:56 AM |
Alan is correct ![]() Mike "Kube" Kubarth
kenburke | -- 04-07-2022 @ 3:12 PM |
Thanks, So the outer corners will be it.
3w2 | -- 04-10-2022 @ 4:52 PM |
A straightforward way to remember the trademark orientation is that the engineering drawings were only made for the right side piece of glass when there were two pieces of the same shape of glass used on opposite sides of the car. The bugs were always readable on the engineering drawing and therefore from the outside of the car when installed on the right side of the car (and readable from the inside when installed on the left side of the car).
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=15585 |
