cub 45 | -- 03-21-2022 @ 6:23 AM |
How do the clips get crimped on the window anti rattle strip? I can't seem to find a good way to do it. This is the strip on the door not garnish molding. thanks kurt
cub 45 | -- 03-25-2022 @ 2:34 PM |
I guess nobody has replaced the window track ect in there cars.
RAK402 | -- 03-25-2022 @ 2:48 PM |
Can you post a photo of exactly what you are working on? I have the right, front window out of mine right now-maybe I can help?
kubes40 | -- 03-25-2022 @ 3:48 PM |
Kurt, These can test a man's patience. I have found it easiest to install the clips to the door. Then, hold the strip in the clip and with a flat blade screw driver, punch the clip closed. If you have help, someone to hold the strip in place, your life will become easier. I typically close the clip in two to three spots. Mike "Kube" Kubarth
cub 45 | -- 03-26-2022 @ 5:23 AM |
Thanks Mike, that's the way i was going to do it but the clips seam to be pretty tough and did not want to bend the lip inward. Will get it done. thanks kurt
kubes40 | -- 03-26-2022 @ 7:02 AM |
Kurt, Prior to installing the clips to the door, bend them over a bit. They only need to be open as much as necessary to push the strip in place. Being bent over quite a bit, will help (a lot) in the final bending process. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=15546 |
