fortyford | -- 01-14-2022 @ 7:01 AM |
I noticed my Coker tires on front are wearing on the inside.Is there an adjustment for this problem on a stock 40 coupe?
carcrazy | -- 01-14-2022 @ 7:50 AM |
Wear on the inside edge could be caused by either or both, too much toe-in or negative camber. If caused by too much toe-in the solution is simple, just adjust the tie rods by rotating them to bring the setting to specification. Too much negative camber could be caused by either worn kingpins and/or bushings or a bent front axle. If the axle is bent, it can be bent back into the proper dimensions by a front end shop that specializes in working on trucks which have solid front axles.
sarahcecelia | -- 01-23-2022 @ 11:05 AM |
Too much toe out; Too much Toe in , would cause the outer side to wear. Camber can do that too. Under inflation causes the outer sides to wear; to0 much inflation causes the center to wear. Get your front end Professionally aligned. Caster, camber, and toe in. Regards, Steve Lee This message was edited by sarahcecelia on 1-24-22 @ 1:12 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=15424 |
