classiclover | -- 12-20-2021 @ 6:03 AM |
Greetings Having trouble eliminating noisy fan belt. Tightening doesnt seem to work. Belt appears to be in good shape. Any suggestions. All inputs appreciated Classic Lover
same | -- 12-20-2021 @ 7:05 AM |
Hey,classiclover, are all pulleys running straight and tru? if not belt,could be bearings not well in water pumps. years ago people used belt dressing on the belts. i believe because the belts left to long running loose too long pulleys would get a glaze. the belt dressing was a pine tar substance. use a auto stethescope to listen to water pump. tom.
37RAGTOPMAN | -- 12-20-2021 @ 8:58 AM |
squeaky fan belt do you have the correct belt. pully angle and depth ? how old is it ? is it hard, ?? it the belt riding on the bottom of pulley ? maybe causing it to slip, ?? is it a after market belt, NAPA believe it or not they may have a listing for your 1940 they have the correct belt for my 37 85 hp BELT DRESSING is a temp fix if at all my 2 cents 37 Ragtopman , Maine
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=15367 |
