cpipp01@aol.com | -- 08-19-2021 @ 4:53 PM |
I was taking apart a 40 Ford hot water heater and the blower fane does not look right. I thought the fan has 6 blades and is this the correct 6 volt heater motor? Thank you in advance for any help you can give. Dave
40 Coupe | -- 08-20-2021 @ 5:14 AM |
You are correct the blower motor should have 4 wires coming out of it. Yes the fan impeller is incorrect it should have two impellers one with 6 rectangular shaped blades and circular squirrel cage impeller. Between the two impellers is a cone shaped plate.
pech33 | -- 08-20-2021 @ 1:10 PM |
You probably have a two speed (non-reversible) fan motor. The pictures I have posted are what I took out of my 40. Six blades, squirrel cage and four wires. Pat’s 40 Ragtop
cpipp01@aol.com | -- 08-20-2021 @ 2:09 PM |
Thank you for the photos and information. To bad the motor works great. Thanks again Dave
40 Coupe | -- 08-21-2021 @ 5:47 AM |
If the motor works well it can be rewired to make it reversable. The motor wiring harness is reproduced. The switch resistor makes the motor two speed.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=15090 |
