cub 45 | -- 05-27-2021 @ 9:01 AM |
Where can I get the battery with the posts in the correct location, nobody around me can get one. Don't want a $400 ford script for a driver, could go with optima but would like to keep org look. thanks kurt
carcrazy | -- 05-27-2021 @ 10:02 AM |
You can buy a reasonably priced ($104) 6 V battery for your '40 Ford at NAPA. It is the correct size, BCI No. 1. The terminals are on the top of the battery but not in the locations of the terminals on your original battery. You may have to purchase a longer cable to connect it to your car. The NAPA part number for this battery is BAT 7244.
cub 45 | -- 05-27-2021 @ 11:28 AM |
I have that battery in the car now with a 1/4 rubber pad wedged between the inner fender and bat that folds over the terminal to keep it of the inner fender and hood. Would like to find a bat that the term is to the inside . thanks kurt
1931 Flamingo | -- 05-27-2021 @ 3:03 PM |
The 6volt battery I got at NAPA had the posts in the correct location. I forget the number. Paul in CT
cub 45 | -- 05-27-2021 @ 3:37 PM |
Could you look at the bat and respond with the no ,myself and others might like the information
trjford8 | -- 06-01-2021 @ 1:28 PM |
You can order batteries from Napa with the correct terminal configuration.
cub 45 | -- 06-01-2021 @ 2:22 PM |
tried they can't come up with a darn thing.
1931 Flamingo | -- 06-04-2021 @ 11:02 AM |
Sorry for getting back to you so late. NAPA 7204N, 6 volt, posts in the right place, fits securely in the battery tray. Depending on how big your MAPA is they should have one or be able to get it from their warehouse in a day or so. Hope this helps. Paul in CT
cub 45 | -- 06-04-2021 @ 2:46 PM |
thanks Paul, will look into it. where in ct I lived in newtown fo 57 yrs , now in sc thanks kurt
Barney | -- 06-04-2021 @ 6:05 PM |
Hi, I bought one recently at TSC (Tractor Supply Co.) Barney
1931 Flamingo | -- 06-05-2021 @ 6:41 AM |
Kurt, I grew up in Forestville (Bristol), have lived in New Britain the last 49 years. Paul
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=14864 |
