bo8109b | -- 01-12-2019 @ 3:50 PM |
Awhile ago I installed a new headliner in my "40 Sedan. Now, I want to install the sun visor brackets. Problem is I didn't take photos of their location and I'm trying to feel through the headliner where they go. Can someone give me precise measurements or a photo of where they go. Am scared silly of puncturing that headliner in the wrong place. Carl
kubes40 | -- 01-13-2019 @ 6:33 AM |
Carl, You should be able to feel with your finger tip, the three holes beneath the head liner material. I might suggest, if you are nervous about this... make a small (cardboard) template from your visor bracket. Once you think you've found one hole, put the template up there and see if the other two align. I use a pin to puncture the material when I am fairly confident I've located the holes properly. Mike "Kube" Kubarth
bo8109b | -- 01-13-2019 @ 3:15 PM |
Thanks Mike, Good outcome on that visor bracket install. That template idea cinched it. Carl
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=12619 |
