thunder road | -- 11-09-2017 @ 10:42 AM |
Mike, Tom or anybody can you tell me who the original manufactures were that produced the gas caps for the 1940 Ford's. Was the Everseal #1603 or Stant #G25 or the #749 from the Badger tool & Mfg. Co. Chicago. U.S.A. Are any of these correct? Domenic This message was edited by thunder road on 11-9-17 @ 10:48 AM
kubes40 | -- 11-09-2017 @ 1:53 PM |
The one in the photo does not appear to be correct. However, pictures are not the best source to inspect minor details. Mike "Kube" Kubarth
thunder road | -- 11-09-2017 @ 4:05 PM |
Mike thanks for the input. Dose anyone have a picture of an original 1940 Ford gas cap? If so please post. Domenic Domenic This message was edited by thunder road on 11-9-17 @ 4:06 PM
kubes40 | -- 11-09-2017 @ 6:04 PM |
I can't seem to take a good picture. Not one with enough clear detail that would help. I can tell you this: The outer edge had a rolled knurl to aid in gripping. This 14 pitch (14 per inch) knurl was approximately .210” wide. The inner steel pieces were cadmium plated. A brown fiber gasket provided the seal between the filler tube and cap. Being a vented type design, a .090” diameter hole centered in the rivet was only visible when the cap was removed. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=11366 |
