alsmith39 | -- 02-21-2017 @ 5:11 AM |
Should the crossover exhaust pipe be put on before engine placement ? I need to get my anti chatter rods in place yet and am thinking that I need to loosen the engine mounts so the rods fall into place. I know that it will be a small amount of movement but I hope that the pipe will clear the ittle plate comming off of the frame crossmember. It was a lot easier to build my street rod from an old junk car than to get this Ford on the road again.
kubes40 | -- 02-21-2017 @ 5:45 AM |
You may be able top get the engine in with the pipe attached. However, I have found it to be quite easy to install the pipe after engine installation. I tend to leave both the crossover and exhaust pipes semi loose until I have them aligned to one another. Then, and only then, do I secure them.
alsmith39 | -- 02-21-2017 @ 2:20 PM |
Thanks for the reply> Allways get good info on this forum.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=10531 |
